How to reset radio after entering wrong code 11 times (11 error) Before "enter code" appeared, but not anymore.. Br Morten
SOURCE: P reg Nissan Micra radio says ''secure''. I cannot enter code.
Either the code you are using is not correct or your method of entering it is incorrect as your radio is not recognising the code..
To reset it from SECURE, leave it SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself . Could be many hours ....but normally only an hour or two.
If you want to check that you have the right code then POST ANOTHER QUESTION quoting the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Testimonial: "good prompt answer tho' still not sure of initial procedure that caused immediate problem"
SOURCE: My ford bantam radio is locked after the key code
Phone your local Ford dealer. I'm sure they will inform you that it must be sent in to have a new code programmed into it. Probably expensive, like a hundred bucks.
Not the news you wanted to hear, I know.
SOURCE: How to enter code for freelander 1998 Radio R770
Philips / R770 Rover Code Entry
Switch on the radio, the display will show 'C'
Press [P1] followed by the tuning button to rotate the first digit
Press [P1] followed by the tuning button to rotate the second digit
Press [P1] followed by the tuning button to rotate the third digit
Press [P1] followed by the tuning button to rotate the fourth digit
Finally if the correct code is shown on screen press the [P1] button to save the code.
SOURCE: Eurovox stereo in Holden VT Commodore code won't work anymore
My ford dose the same thing you will need the original car booklett in it sould be a little white card which has the code on it! if you have not got the card/book go in to a holden shop or ring up Holden motors
SOURCE: FORD 2007 RDS KEY CODE RADIO CASSETE PLAYER CODE ERROR
try holding down button 6 while you turn it on. This may give you 3 more attempts to enter the code.
