Epson Workforce 520 Printer Logo
A
Anonymous Posted on May 10, 2012
EPSON Workforce 520 FATAL CODE:0xF1
Printer repeats Printer error Fatal Code:0xF1 and won't respond to any commands
Hampi Hemp
Level 3:
  • Epson Master 706 Answers
  • Posted on Dec 05, 2014
Hampi Hemp
Epson Master
Level 3:
Answers
706
Questions
0
Helped
238409
Points
6294
  • Julian Roberts Mar 30, 2016
    I had this error and paper was jammed, but also the print head as stuck like the next answer below. There was a little plastic lever stuck up below the print head. I moved the print head carefully to one side, pressed the white plastic lever down and it clucked into place. Moved the print head back to the right and switched on. It then complained about the paper jam. Pulled that out and it was good to go. Maybe the jam caused the other problem?
  • Anonymous Aug 17, 2017
    yes ! a paper jam. everywhere else I looked gave me complicated responses
Jessica Davies
Level 2:
Novelist:
Scholar:
  • Epson Expert 101 Answers
  • Posted on Jan 29, 2020
Jessica Davies
Epson Expert
Level 2:
Novelist:
Scholar:
Answers
101
Questions
Helped
143535
Points
435
Call Toll-Free + 1-866-231-0111 Epson Error Code 0xf1 is called a commonly encountered key error owing to corrupted computer system registry entry. While this error code appears, during its initiation mode, the print head will not be able to conduct its regular function or even not be able to read any document from the left or right side. Print job will be until and unless you exterminate your Epson printer with this error code.
Steps to Fix Epson Error Code 0xf1
Usually, Epson Error Code 0xf1 indicates a defective PC entry. If your printer displays a 0xf1 error code error message, this implies that your printer will not be able to read the inserted records from either left or right and you will not be able to continue any printing process.
Solution of Epson Error Code 0xf1
Fixing Paper Jams Issue: If you discovered any piece of paper in the feed roller or paper cabinet, turn the printer and thoroughly open the paper output cover. Clear all obstacles in the form of dust, paper or debris from the feed roller, paper tray and under the cabinet and switch the printer on again.
Fixing Printhead Issue: If you have discovered a defective printhead that causes trouble, remove the printhead, clean it and correct it again. If the issue continues, it will require an updated printhead version. Buy a fresh one with a piece of expert guidance.
For More Information Visit: http://www.printercustomerservice.co/blog/epson-error-code-0xf1/
5 Related Answers
Anonymous
  • Posted on Sep 25, 2009
SOURCE: I have the picture mate personal photo lab and the error code 0x2 comes up when I turn it on and I am not able to do anything else
I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
Anonymous
  • 41 Answers
  • Posted on Jan 22, 2009
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Anonymous
  • 31 Answers
  • Posted on May 22, 2009
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
Anonymous
  • 11 Answers
  • Posted on Jul 07, 2009
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Anonymous
  • 558 Answers
  • Posted on Sep 21, 2009
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
1helpful
2answers
What does the Epson error code 0xf1 mean?
The Epson error code 0xf1 is an ink cartridge error. It means that the printer cannot recognize one or more of the ink cartridges installed in it.
5answers
How Do I Resolve Epson Printer Error Code 0XF1?
You are getting late for a presentation and have given a print command to your printer. Your printing operation is in process and suddenly an Epson printer error code 0xf1 appears. Pretty frustrating, right? If you are in mayhem and looking for methods to fix the printer 0xf1 error code, you are at the right place.
The major issue with this Epson printer error code is that it hinders all the ongoing printing. This glitch prevents the printer head to move right or left, and hence mars the functions. The problem could be due to some hardware or software blunder. Irrespective of the root of this problem code, this article provides a comprehensive answer to how to repair error code 0XF1 on an Epson printer; and the best part is you needn't be an expert to do it and could implement it it it with ease.
What causes Error code 0xf1 issue in Epson Printer
The Epson printer 0xf1 error problem can stem due to numerous causes. The reasons could be:
  • The registry entries are corrupt.
  • The drivers are obsolete.
  • The system is infected with malware or virus.
  • There is a stuck piece of paper in the printer.
Fixing Epson printer error 0XF1 There are 3 easy solutions to resolve this problem. You could try any of the methods to resolve the issue.
  1. Turn off your Epson printer and remove its power cord. Turn it on again. At times, restarting the printer resolves the issue. To add, also conduct an antivirus scan to remove any viruses.
  2. Uncouple the ink cartridges and affix them. Also, inspect for any paper jams.
  3. Switch off the printer and remove its power cords. Wait for 10-15 minutes. Once the time elapses, attach all the cords and turn on the printer.
Also Read: Epson connect printer setup utility
Getting error code OXF1 on Epson WF 3640
Epson Workforce WF 3640 error code 0xf1
It published a solution for the 0xf1 error code. They claim that this error can occur because of a corrupted registry entry in your PC. They say that the print head will be unable to go or read from left or the right side while it is performing the printing process
Steps To Fix Epson Printer Error Code 0xf1. This technical issue might due to software or hardware problems with your printer or computer. The main step that you can perform is to unplug the printer from the main socket, remove the printercartridge, and then reattach it.
2answers
My Epson WF 2650 printer is showing error code 0xF1, how do I fix it?
Please check for paperjams within your printer tray. Remove any pieces of stuck paper, then restart your printer and your error should go away. Thank you.
3answers
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Printer repeats Printer error Fatal Code:0xFA and won't respond to any commands
It is obvious that you didn't download the correct driver or if it is new, you didn't remove the packaging properly. Please check all the cable connections.
4helpful
2answers
Epson workforce 520 error: won't do anything.
Great job, yup there are sensors and switches that need to be triggered if they are not errors will be thrown.
1helpful
3answers
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
