I only got it this afternoon to find out that it isnt even working :( absolutely gutted!!! :( Please help ***
See my block diagram for treadmill and see the fuse.
1) This ocurre for varios reason a) test the swicht power for short circuit.
2) the capacitor shor 3) the coil is short 4) the board is short.5) The power cord some wires is touche the carcase from treadmill, or some other wires inside is touching , test it
Now you must isolate the short with DVOM.
God bless you
SOURCE: help, my Reebok 8700 ES treadmill won't work...
I had the same problem happen today!! I called 188-999-3756, they are sending my a new panel for 5.95! Yes, I bet that many owners of this treadmill have had the same thing happen. Mine is only 8 months old! let me know if you get this message.
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
SOURCE: Reebok 8050es treadmill walking belt has started
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
