Dryer want power up no lights on leds
SOURCE: Neptune Maytag MDE9700AYW
Remove the screws from the bracket from the vent tube at the back of the dryer.
You can access the belt from there.
If the belt is off then the tensioner will push a switch to shut the dryer down.
Just hook the belt back on or replace the belt whatever needs to be done.
See other posts for this model number on how to connect the belt back if it came off.
They do that when turned the wrong direction.
SOURCE: Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
SOURCE: Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
SOURCE: Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
SOURCE: belt diagram for maytag neptune dryer MDE9700AYW
the belt came off the pully and I need a diagram to see how it goes back on properly
