Does not function on ultraviolet mode..ray
[email protected]
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Hi.
I don't know if you still use your ionic breeze.
About Ionic breeze purifier, I want to call attention on the fact that they are not
being manufactured anymore because of heath concerns. New model use a
completely different technology. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
I have 2 of these overpriced, no good, now out of business machines. They both did the exact same thing. Blue lights blinking, sparks, smell like something is burning and now just don't do anything! Has anyone a solution????
Blue lights were blinking constantly. Then even after cleaning thoroughly it would do the same thing. Then we noticed a funny smell and the light wouldn't work. Now neither machine even shows that it is even on or working. We have the Sharper Image GP (2)
piece of ****. thats why the company went out of business.,, they give offf high levels of ozone and thats why the air smells weird!!!
I too have the pro series ionic breeze gp silent air purifier. I had an issue once and sent it back to sharper image since it was still under the 5 yr warranty. Once I got it back they had fixed the broken wire but upgraded the back panel with a honey comb grill. That wasn't there before so I figured they did me a solid favor. But after reading a few post and finding out about how they went bankrupt I do too wonder who can service these units. Now my Gp or Boost light doesn't come on but the black light does turn on when on GP mode. Plus this weird metallic scent emits from the machine. Some say its ozone that is released and can causes breathing problems. What to do now.
