Question about Motorola Mobility H500 Wireless Headset
Motorolla h500 no steady blue light
Trying to raie motorola H500 with my black berry 9870. Bluetooth not giving me a steady blue light, I tried many times and still nothing. PLZ help :-(
  • Viktoriya May 11, 2012
    bluetooth was connected to a different blackberry previously....not sure if thats important
    never mind lol got it...thank's anyways :-)
    President:
  • 1,118 Answers
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
Posted on May 12, 2012
6ya staff
SOURCE:
DENNIS MITCHELL
  • 1003 Answers
SOURCE: H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Posted on Jan 17, 2008
Anonymous
SOURCE: Motorola H500 Wireless Headset Pairing Problem
If you turned it on and it was steady blue most likely you held the call button too long. The steady blue means it's ready to pair with a phone. Try repairing again and if you still don't hear anything, play with the volume buttons to the top and buttom of the headset the volume may be down. If that doesn't help I don't know what will.
Posted on Sep 21, 2007
Anonymous
  • 55 Answers
SOURCE: Pairing Motorola H500 Wireless with Blackberry
Try the steps listed in the solution found here
http://www.blackberryforums.com/general-blackberry-discussion/18109-bb-7520-motorola-h500-pairing.html
Hope that helps
Posted on May 01, 2008
Anonymous
  • 320 Answers
SOURCE: MY BLUETOOTH FOR MOTOROLA H500 I LOST THE PASSKEY AND I USED THE DEFAULT PASS KEY AND IT SAID FAILED TO CONNECT
The passkey is default set for all Motorola headsets at 0000. try that. If this works, be sure to rate the solution. Thanks!
Posted on Nov 08, 2008
Anonymous
  • 6 Answers
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Posted on Mar 14, 2009
It won't turn on. how do i fix it?
A steady blue light means it's in "pairing mode". Did you try to pair it with your phone during this time?
Aug 22, 2009 | Motorola Mobility H555 Bluetooth Headset
Pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Mar 06, 2009 | Cell Phones
I have a Motorola H500 BlueTooth headset. I'm trying to setup the headset to turn on and I'm trying to follow the instructions on how to turn on the device by holding the Call button to for 6-7 seconds but...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 11, 2008 | Motorola Mobility H500 Wireless Headset
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
How do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
Motorola bluetooth H500
A few days ago I paired my razor to my blue tooth1.gif and t was working just fine but the next day it wouldn't work and every time I tried to connect it it would say I NO DEVICES FOUND. I tried reseting the phone but that did not work and I don't know what to do. Can you PLEASE HELP ME!
Jan 27, 2008 | Motorola Mobility H500 Wireless Headset
How do you connect a Motorola H500 Headset to a motorola razor v3m
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Enjoy!
Jan 14, 2008 | Motorola Mobility H500 Headset
Hi help plz
What type of phone do you have? When you try pairing with your phone are you sure you have activated the option? If not, here's what to do. Hold the call button on the H500 until the blue light stays on, then with your phone go to the bluetooth option and select search for devices. It should be able to find it then.
Sep 03, 2007 | Motorola Mobility H500 Wireless Headset
Aug 20, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
231 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
