Error c0180 correction
If reseating connectors on mainboard do not solve then:
1087 1087 get in to maint.
004 START
Choose the 003 line by touching it and activate it.
Reboot when told to.
This could be the hard drive problem,then what to do you should change or get new hard drive trust me that error code will disappear
First power off the machine
Next open the Front Cover and Right cover
then power on the machine wait 15 seconds and close the Front and Right Covers
SOURCE: error code is 0180
mr rupabai your problem is in the magenta starter try to intialiaze it again by pressing " 28 at the same time
copier
function
install
int m press it and wait a few minutes if an error occured after intializing change the magenta starter and intialized again
SOURCE: Error message on copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
SOURCE: My Kyocera Mita KM-C380 copier check waster toner tank
Hello sir; the waste toner tank haveto be clean up thoroughly, aspecial the bottle neck .
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
SOURCE: Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
The machine failure Dialog box fails to disappear
c 0180 disply machine not going semulation
