I have a 1999 rca 27 inch tv I began to get a green spot in top left corner, then i began to get red streaks on the back of peoples heads as they moved, and finely the screan took on a purple shade ,you can still watch tv if you dont mind purple ,what is the problem.
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
can anything be done about it
