Question about Sennheiser HDR 120 Consumer Headphones
Sennheiser 120 green light goes off
I have had 2 sets of these headphones and stands. Everything worked fine with them for a few months. Now the red light goes on when charging but the green light no longer goes on and there is no sound to the headphones (besides static). The sound is set correctly and I even turned it way up, the channel is right but still nothing.
    Habit-Forming:
    New Friend:
  • 87 Answers
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Posted on Nov 12, 2017
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
JustPatrick
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
JL Thompson
  • 155 Answers
SOURCE: There in no green light
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Posted on Apr 24, 2009
JL Thompson
  • 155 Answers
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Anonymous
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Red and white cables?
My Sennheiser comes with a black and red cable. I plugged the red into the red in the back of the tv and the black into the white in the back of the tv and it works for me. Hope this helps.
Mar 22, 2013 | Sennheiser RS 120 Consumer Headphones
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
Jan 26, 2009 | Sennheiser RS 120 Consumer Headphones
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Sennheiser HDR 120 Consumer Headphones Logo
296 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
