Question about Dryers
Whirlpool tumble dryer making a loud noise - Dryers
  • 10,319 Answers
The dryers drum that spins around is driven by a belt . A belt tensioner is attached to provide a secure fit when turning. The tensioner has a idler pully which has a bearing in it. When worn the bearing squeaks or wears out causing this noise you have. Sears sells the belt and idler pulley as a set to retify this situation you have. Instructions come with these kits
Posted on May 12, 2012
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: hotpoint tumble dryer is making
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Posted on Feb 14, 2009
Anonymous
  • 22 Answers
SOURCE: hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Posted on Nov 19, 2009
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Posted on May 02, 2010
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: The dryer makes a fairly loud squeaky noise when
DEGX1 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 23, 2010
Testimonial: "The service manual is a huge help. I can now fix my dryer with proper instruction."
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Dryer making loud noise while tumbling like a knocking sound.
Probably need to replace rollers. There are two at the back of the drum, and depending on the model tehre might be two at the front of the drum. It should be pretty obvious which one is the problem, it will either be really loose, or have a flat spot.
Jan 30, 2011 | Whirlpool Dryers
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
What is the noise coming from my dryer?
Good Afternoon,
If the shipper has insurance they should replace the dryer. No?
Mar 27, 2009 | Whirlpool LER5636P Electric Dryer
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Noise from washing machine
heatman101
fddfs
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Dryers Logo
181 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
