Question about Motorola Mobility H500 Wireless Headset
Motorola h500 redials last call on next operation
I've had this H500 new in the package and just recently pressed it into service. I've paired it with my Samsung Galaxy Note Android phone and it works well. My only issue is that it doesn't always connect to the voice speak function on my phone to voice dial a call, most often it just calls back the last call I made. Am I doing something wrong?
6ya staff
SOURCE:
DENNIS MITCHELL
  • 1003 Answers
SOURCE: H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Posted on Jan 17, 2008
Anonymous
SOURCE: H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Posted on Feb 01, 2008
FreeTech
Lee N.
  • 426 Answers
SOURCE: blackberry unable to pair with motorola h500
the pass key is "0000"
Posted on Jul 16, 2008
Anonymous
  • 3 Answers
SOURCE: how do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
Posted on Oct 29, 2008
Anonymous
  • 6 Answers
SOURCE: H500 has worked well until recently. Now when I
the button might be sticking from use, with a small flathead screw driver carefully pry off the silver part above the button area close to the charging port, you will see 2 tiny screws, next carefully with a tiny flat head screw driver, remove the cap over the bluelight area (the one with the symbol "M") and there is another tiny screw there. open it carefully and once open inspect closely the area that holds the button assembly and see if the contact point is either ripped or dirty or if the rubber is just not flexing anymore....
Posted on Mar 14, 2009
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
I have Motorola H500 headset and don't know how to use it with my PC
Unless your computer is already bluetooth enabled (many PC's aren't), you'll need to also purchase a USB Bluetooth adapter. Amazon often sells the two units in a single package.
Apr 04, 2009 | Motorola Mobility Universal Bluetooth...
Connect LG CU515 to Motorola H500 Bluetooth
here is the manual for the lg CU515: http://www.wireless.att.com/support_static_files/manuals/LG_CU515.pdf
however, you should just be able to go to the bluetooth menu, select "search new device" (looking for "Motorola H500"), then press "add" - the passcode should be "0000" (without the quotes)
Feb 03, 2009 | LG CU515 Cellular Phone
How do i connect H500 to my phone
www.simoncells.com
then go to manuals
Good luck guys.
Ed
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth H500
when it asked for the pincode to paired the bluetooth headset enter the code 0000
Jan 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility H500 Wireless Headset Logo
70 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
