Thanks for your reply, Nick61! When I connect other devices in the same USBs, everything works...so I guess the problem it's not the USBs. I'll try connecting in my husband's computer.
Thanks again!Thanks for your reply, Nick61! When I connect other devices in the same USBs, everything works...so I guess the problem it's not the USBs. I'll try connecting in my husband's computer.
Thanks again!
when i cannact the hard drive my desk top no showing the hard drivewhen i cannact the hard drive my desk top no showing the hard drive
AnonymousNov 29, 2008
I tried plugging it into another USB port and that didn't work. I tried plugging another device into both ports and that doesn't work. I am getting an error message: power surge on hub port - device has malfunctioned and exceed power limits of its hub port. I tried plugging it into another USB port and that didn't work. I tried plugging another device into both ports and that doesn't work. I am getting an error message: power surge on hub port - device has malfunctioned and exceed power limits of its hub port.
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Thanks again!
I can not connect the drive
