Question about Olympus Stylus 850SW Digital Camera
Lines through my saved pictures on Olympus 850sw?? :(
My olympus 850sw takes pictures perfectly but i have noticed that when i view the saved photos they have lines all through the photo. i thought i might have an issue with the memory card so i took it out, but still having the same problem. i have uploaded my photos onto my imac but the lines are still there! can anyone help? is it repairable??
6ya staff
SOURCE:
Anonymous
  • 91 Answers
SOURCE: olympus camera fe 240
You can transfer the photos directly from the camera to the PC using the USB cable that came with the camera. You don't need to transfer the pics to memory card first.
Connect the cable to the camera and the PC. Turn on the camera and your PC will recognise it as an external storage device. Use the PC's software to transfer the photos from camera to PC.
Once you have the pics on the PC you can use the Olympus Master software included with the camera to edit and archive the photos on the PC.
Posted on Mar 13, 2008
dewan nafees ahmed
  • 1894 Answers
SOURCE: My olympus FE-190 camera was
it is nothing but the grid lines option turned ON.
go to menu settings and turn it off.
Posted on Jun 16, 2008
Anonymous
SOURCE: Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Posted on Nov 03, 2008
Anonymous
  • 919 Answers
SOURCE: Olympus SP550UZ photos saved on camera memory not card
In the Menu if you go to the option that says Setup and press ok there should be an option that says Backup. This should allow you to copy the images from the internal memory to your xD card.
Posted on Dec 10, 2008
Anonymous
  • 919 Answers
SOURCE: After trying to upload photos from my Olympus 1050
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Apr 09, 2009
My camera doesn't have color and I constantly see horizontal lines how can I fix this
To avoid to much guessing, I think you should try to reset the camera. How to do that is on page 24 and 25 of the manual. With this you exclude things that can go wrong, because of a wrong scene setting or white balance or whatever. After you did the reset in the shooting mode, everything is in automatic again. Then again try to shoot a picture.
It could be the display is giving up. after a few years you can't expect it would work as new. So even if you still see lines on the display, shoot some pictures and put them on the computer. There view the results.
If the pictures are good but the lines are still on the display, try to live with that. Repairs will cost more than a brand new camera of a better quality. If the lines are in the picture, the sensor is defect and I think you should start saving for a new camera. Although new point and shoots can be bought around a 100 dollar. But even some smart phones now can take pictures that should be as goos as the ones that came from your Olympus when it was brand new.
If you can't find the manual, the link here will download it for you:
http://www.olympusamerica.com/files/oima_cckb/Stylus_850_SW_Mju_850_SW_Instruction_Manual_EN.pdf
Dec 04, 2014 | Olympus Stylus 850SW Digital Camera
Olympus Stylus 850SW viewfinder and photos pink and blurry
Pink photos are usually caused by White Balance being set wrong. You should see in the menu the WB icon. Change the icon to the symbol of the sun. Or.... just reset the camera back to the default settings by going to the camera reset in the menu. If this fails, then your picture sensor is needing to be replaced.
For the manual, go to the following site:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1365
Jul 05, 2014 | Olympus Stylus 850SW Digital Camera
My olympus e volt 500 will not display image when in shoot mode
There is a little button on the back, marked 'info'. Press it to switch from picture view to settings view. It also operates the viewfinder.
Olympus also has a good photo editing program that is free and it allows you to edit photos and stitch pictures taken pn panoramic mode into one panoramic picture. It's called Olympus Master.
Dec 12, 2012 | Olympus EVOLT E-500 Digital Camera
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
Oct 18, 2010 | Olympus Stylus 850SW Digital Camera
How i can set date and time on picture of olympus...
The 850SW will not deface your pictures by scrawling numbers across them. However, the data is stored with every picture. Depending on the program and printer, you can print the date on the image, in the margins, or on the back. Please refer to the documentation for the program.
If you print directly from the camera, refer to the instructions in the "Printing" section of the camera manual (page 41 in my copy).
May 19, 2010 | Olympus Stylus 850SW Digital Camera
Photos are not clear and has lines
I have the same problem with my camera. Olympus tech says the lens needs to be replaced at $185+ and it's 18 months old with little use. Not happy, not worth it. Don't buy this camera.
Dec 18, 2009 | Olympus FE-340 Digital Camera
Pictures on memory card
A lot of cameras these days use sub directory folders on the memory stick. Try using a computer to drag all the photos to the top most layer directory on the memory stick.
Nov 13, 2008 | Olympus Stylus 850SW Digital Camera
Nov 12, 2007 | Olympus FE-120 Digital Camera
Olympus Stylus 850SW Digital Camera Logo
81 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
