Question about Brand Remote Start/keyless/car Alarm Very Sleek
Spy car alarm manual
Looking for a spy car alarm installation manual not sure on model number but got photo
  • Anonymous May 11, 2010
    i need to know how i can(accordin to the manual) reprogram the two transmitters again. recently the two transmitters decided to stop working. replaced batteries as well but to no avail.
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Posted on Feb 18, 2009
    New Friend:
I NEED AMANUAL FOR A SPY ALARM MODEL #LC308B
Posted on Dec 11, 2009
  • 22,485 Answers
Forget the boy racer add on they are useless,if i want to pinch it it will take me minutes to silence and by-pass it ......buy a steering lock that fits over the steering wheel complete so air bag cant be half inched either and never leave anything in car worth nicking ,these sort of things take too long to remove,and if you put car into a garage for servicing never leave the key for steering lock with the car keys .Another and cheaper way is to put a switch in power cable to the fuel pump and place switch where only you know where it is behind facia or seat .now that slows them down.Best way to half inch a car is to pick it up with a breakdown truck .no body bats an eyelid
Posted on Nov 22, 2008
6ya staff
SOURCE:
I have a liberty pump in my basement for my bathroom the alarm sound comes on can you please give me an idea whats happening also the red light is on
All the Liberty Installation manuals are here. Look up the model number and check. The alarm means that your sump pump has tripped the switch to come on, but the pump is not clearing within a specified time.
http://www.libertypumps.com/service/manuals
The alarm units are shown here
Alarms
May 12, 2018 | Cars & Trucks
Hi.month ago i install spy 5000 alarm.now the problem is ...cant start the bike because the alarm goes off always
Hi, Georgian read the manual provided in the link below you may need to do an alarm reset for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day
spy 5000m remote start problems ninjette org
How wired my spy 5000m to 2005 kawasaki zx10r
spy5000 alarm manual pdf
2008 2010 Kawasaki Ninja ZX 10R Service Manual Moto Data Project FREE!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 17, 2016 | 2010 kawasaki Ninja ZX 10R
I bought a Spy brand one-way car alarm/remote start for my wife's 09 Camry. Everything is installed, and works except for the remote start.
Installations of this nature are usually reserved for professionals. However, get out your installation manual. You will also need two single pulse double throw relays and some diodes. First you will need to locate the ground when running.This wire might be labeled " (-) third ignition". The first relay for the starter will be wired like so: starter wire to 86, fused 12 volts to 87, 30 out to vehicle second starter wire, 85 to ground when running. The second relay will be wired 86 to vehicle ignition, 87 to fused 12 volt, 30 out to second ignition, and 85 to ground when running.
Jan 22, 2013 | Brand Remote Start/keyless/car Alarm Very...
I need a manual installation guide for a Spy 5000m C1 MODEL
This is the only site I know of that has a manual for the install
and user instructions for this alarm. This alarm is hard to install
but the manual shows you how to do it with diagrams.
http://userguides.50webs.com/spy_5000m.htm
Sep 23, 2010 | Brand Remote Start/keyless/car Alarm Very...
I need to identify the ademco alarm as it keeps whining to be able to download a manual. The alarm was installed in 2000 and I cannot find the manual to reset. I do however know my own numbers but the...
Look for the control panel (Not the keypad unless it's a Lynx model). If it's not a Lynx, then the control panel will be in a beige metal box somewhere, usually in a closet, basement or other space. The model number is usually on a diagram inside the door.
Sep 20, 2010 | Home Security
I've installed the spy alarm system a couple months ago and it never worked right. I have to constantly press the buttons for it to do what i want it to do..most of the time, the system don't react to my...
There could be an issue with the antenna. Is it mounted on the windshield? If so, try moving it to a different location. You didn't mention the year, make, model of your vehicle but, some cars have a filament in the windshield that interferes with RF signals.
Sep 15, 2010 | Brand Remote Start/keyless/car Alarm Very...
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Brand Remote Start/keyless/car Alarm Very Sleek Logo
15,976 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
