Question about Umax PowerLook III Prepress Flatbed Scanner
Umax powerlook III scanner not working with latest mac system sof
Scanner software ceased working with latest system, found scanner software that did work and all ok, months later at next upgrade of system stopped working, contacted software vendor who managed fix. Next time operating system was upgraded (latest mac) scanner software ceased to communicate with scanner - it doesn't see it. Software vendor reckons the problem lies with apple. I have a very good scanner that I dont want to replace. Any ideas please?
  • Anonymous May 11, 2010
    well..when an operating system migrates like apples, it is up to the vendor(Umax) to keep up, not the other way around. go back to Umax, website, and look for model specific updates to the new apple o/s..only way to do it.
    Top Expert:
  • Umax Master
  • 30,806 Answers
Pity. Windows does the same.
Old machines need old OS because the manufacturer doesn't keep up.
Posted on Jun 23, 2017
    Top Expert:
  • Umax Master
  • 12,962 Answers
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
5 Suggested Answers
Anonymous
SOURCE: Umax powerlook 3000
The UMAX diagnostic code page is here.... http://www.umax.co.uk/support/service/diags.htm
Posted on Dec 09, 2006
Anonymous
  • 85 Answers
SOURCE: umaxUmax PowerLook III Flatbed scanner not support in windows xp
After checking the UMAX site for XP drivers, choose whatever is the latest drivers they provide, and then try to install them as normal. If it installs normally but does not run correctly, right-click on the executable for the scanner program and choose PROPERTIES and then adjust the COMPATIBILITY MODE to Win2000 or WIn98 and try running it again.
If the drivers for the scanner will not install, I had good luck tricking the operating system into installing the drivers by changing the OS description in the .INI file of the driver package, though this is something not so easy to do.
Good luck...
Posted on Nov 16, 2007
Anonymous
SOURCE: Update driver for UMAX Astra 2200 for Mac OS X
I believe that Silverfast (www.silverfast.com) provide software that will run Astra 2200 on Tiger...
Posted on Feb 17, 2008
Anonymous
  • 1463 Answers
SOURCE: OCR Software compatible with umax scanner
you can download a driver from here Umax PowerLook 2100XL 4.50 Driver Download
hope this helps
regards
riz.
Posted on Mar 14, 2008
Anonymous
  • 91 Answers
SOURCE: Umax PowerLook 2100XL - Driver
Go to
this download page on the UMAX site
and select your device (Scanner), then your scanner model (Powerlook 2100XL) , and your operating system, then press the "SEARCH" key.
Each page in the Download Area is in two languages - first German, then English, so page down to the English section.
Follow the instructions to download the correct driver for your scanner / operating system combination.
Note there is currently no driver available for Windows Vista.
When you've tried this solution, don't forget to rate it !
Good Luck.
Posted on Apr 28, 2008
How do I connect my Umax Powerlook III to my max 10.6.8 os x?
This scanner is Fast SCSI . It was made in 2001. You will need a card in your Mac for a SCSI interface. The cost of the card and scsi cable, if your Mac will accept one, will probably exceed the cost of a newer, high performance scanner. Time to move on? (Umax were not the greatest scanners even when they were made. Umax was a cheaper brand with mediocre software. So how will you get the image into the Mac once you have a connection? Power PC (OS 9) Mac software will not run on OS X.)
Feb 27, 2015 | Umax Office Equipment & Supplies
Magicscan not working with umax scanner II .
Magician 4.5 is available at UMAX Official Site.I recommend that you visit Umax site and download the latest available drivers/software and install them. Also, there is a registry fix available, which may solve the issue.
Good Luck!
Hope this helps!
CreativeTECH
Dec 22, 2010 | Umax PowerLook 1100 Flatbed Scanner
All scans with Umax Powerlook III are totally black around the edges with strange color bars where the images should be. This is using Umax Silverfast 6.0 software on a Mac running OS 10.4.11
sounds like the scanner is dead. only way to be sure that its not a software issue is to try that scanner on another machine. if you get the same issue on seperate machines, its a good bet that scanner is toast. Fortunately, you can usually go to the Salvation Army or Good will, and get a used scanner for 15 bucks, all you need is downloaded drivers and appropriate cables.
Jul 21, 2009 | Umax Astra 2100U Flatbed Scanner
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI Converter...to solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works great...no need for a SCSI card...or a driver...you just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
Mar 23, 2009 | Umax PowerLook III Prepress Flatbed...
Vertical colored lines in a scan
If the lines appear in the same location everytime, then it is from the scanner glass. Clean it thoroughly. No solvents except Isopropyl alcohol for cleaning.
S. Mohan, India
Mar 02, 2009 | Umax PowerLook III Flatbed Scanner
Umax Powerlook 1100 with Mac OS 10.5?
Long ago I had to resort to a third party scanning software, called VueScan from Hamrick Software. Works just fine now.
Dec 01, 2008 | Umax PowerLook 1100 Flatbed Scanner
Umax powerlook III
I had that problem...it sounds like a SCSI bus problem...If you have a Mac...you can get a Ratoc SCSI to firewire converter...it solved my problems..Take Care, Carole
Aug 26, 2008 | Umax PowerLook III Prepress Flatbed...
UmaxUmax PowerLook III Flatbed scanner not support in windows xp
Good luck...
Nov 16, 2007 | Umax PowerLook III Flatbed Scanner
Umax PowerLook III Prepress Flatbed Scanner Logo
156 people viewed this question
Top Umax Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
