When changing the channel (3digit number) using favorite touch screen, the remote sends a false signal{?} and the channel i wand does not show on the tv
1) change the batteries by new one type alkalines
2) Retight the springs contact with plier very well for a GREAT contacts.
3) Clean the contacts with special spray contacts.
4) Resolder the wires contacts.
4a) RESET the code or download form www.fitness.manualsonline.com or www. remotecodelist.com
5) Otherwise you must open the remote, for clean the keypads very well with alcohol isopro. or you must go to the repair shop.
God bless you.
SOURCE: need codes for remote
have you tried these codes
http://www.hifi-remote.com/manuals/manual.shtml?URC-3605-codes
SOURCE: On my Samsung LED TV Series 6 I can't use my remote to
You should be able to receive a replacment remote under your limited parts warranty. If not, there are several resources on the web.
SOURCE: Logitech 900 remote won't change TV channels now
There are a number of reasons that this has occurred.
The simplest is that the batteries are low. Change the batteries first. Batteries last 2-3 months before they need replacement.
Try reprogramming the remote. Before you reprogram make sure that you have the latest firmware loaded from
http://www.logitech.com/en-us/440/5874?section=downloads&bit=&osid=1
One of these solutions should correct the problem. Let me know.
Thanks.
sometimes and who knows why the incorrect channel is tuned to when i touch a favorite channel icon. it does not happen all of the time. all my channels are 3 digit numbers.
