I ran a Microsoft fixit sweep of my computer and it shows it shows ISATAP ADAPTER , and adpter #2,#3,#4,and tunneling adpter have a driver problem, but it couldn't fix it with its auto fix, where do I need to go to fix this problem? Thanks,John C
If the drives are working, leave it be. There can be false positives. If the drives are slow or some thing else is odd, try the following solutions. Try to locate the driver needed by going to system devices and looking for a yellow or red icon next to a device.
If there are no marked devices, you are probably ok.
Computer icon, properties, select device manager.
Open the properties for that device. details tab, properties and select hardware id. Copy the hardware id information and google it (sample:IDE\CdRomATAPI_iHAS324___B_______________________AL1A____ trimmed and adjusted becomes IDE\Cd Rom ATAPI iHAS324) Find drivers for that hardware if you can and update. You can also just uninstall the device and click rescan from the device manager menu. It should reinstall.
SOURCE: I have a problem with Microsoft ISATAP Adapter #3 driver
yes maybe its inside the computer or download a fresh driver
SOURCE: ISATAP Adapter #26 not installed
http://www.soft32.com/download_175416.html
This is kinda Microsoft. See if you can dig around here for your version if this doesn't work. Good luck, and rate, if helpful of course.
SOURCE: Unable to load driver software & losing internet connection
What if you remove LAN cable and boot without it.
SOURCE: i need a driver software of microsoft isatap
do one thing -- open DEVICE MANAGER--> and uninstall the adapter ,then REBOOT .....
Nothing else to do, Windows will do the rest. And you can ignore the errors altogether if you wish and on some computers it will always be there but cause no problems..
also refer :
http://support.microsoft.com/kb/932520
SOURCE: Recently,i formatted my notebook but
Greetings,
You need to download and reinstall the device drivers and system software from your notebook manufacturer's website or reinstall from your system CD. The exclamation point means just that, the device is unable to start because the required DLLs and supporting software are missing.
Testimonial: "should i reforrmatted it?? I'm sorry,,can you pls tell me how can i do that.. what cd should i use? i have a window 7 starter cd, pre-installation dis"
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
