You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
It won't turn on and it won't even power on and stay on I'm trying and trying to reset it, is there anything else I can do?
Well I just called the manufacturing company and on the back of my tablet I held down the small reset button for 10 seconds and powered down and have to let charge for 2 to for hrs does anyone know if this will work??..
SOURCE: My cruz reader opens to
it is happening to me too, but on the android. and it skips and then goes back to the android, help me pleaseeeeeeeeeeee!
SOURCE: my velocity micro cruz won't
Hold down the power button - even after the shut down message for a minute or so - then restart.
SOURCE: I just received a new
Make sure your power cord and the outlet you're plugging it into aren't damaged in any ways. It's possible the power cord is damaged, or the battery is bad. Both of which you can fix easiest by contact Velocity directly.
SOURCE: I have the Velocity Cruz
try to clear some cache files from your tablet pc.. check your tablets internal memory, then select the files you would like to transfer
SOURCE: I can't get wi-fi connectiion
Welcome to Fixya
First, make sure that WiFi is enabled on the Cruz Reader. From the Home Screen, select Wi-Fi Settings and ensure that both Wi-Fi and Network Notification are enabled with green check marks. After your unit search for network, your Wi-Fi networks list should populate. If you need to rescan, tap Menu> then tap Scan.Detected networks will appear with a SSID to the left, a status line beneath the SSID, a signal strength icon to the right. Those that are secure will also feature a padlock. Tap the network you wish to connect to, then click Connect. If a password is required, tap the text field for the popup keyboard. If you need to configure a connection manually, choose Add Wi-Fi Network> enter your router's SSID> select security type if any and enter password> and Save. Once the Cruz has successfully connected to any SSID, it is saved. When that SSID is no longer available, it is listed in the Wi-Fi networks list as "Not in range, remembered" in the status line.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I can download apps,but can't. Open them.
My apps will not open when I click on them
