Sony KV-32S26 32" TV Logo
Brad Jamesson Posted on Dec 23, 2006
Slanted picture!! Hi, The picture on my television set is slanting down to the left (as if the right side of the TV is raised higher than the left, but its not of course). The TV is perfectly level so I know it is an internal problem. Can anyone help with this?? Please let me know. Thanx.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2006
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
890
Points
This problem might be caused by an external magnetic field. Most modern Sony tv sets have a picture rotation control. Go to the setup menu and select Picture Rotation. Your user guide will explain.
  • Anonymous Jan 04, 2007
    Check to see if the scan coils on the tube neck have not moved.
Picture is slanted left to right.
Check and replace the main digital processor board. Synchronization problem, along with phase.
The HD video input channel has a slanted, dual picture.
check for the settings or the inputs doesnt match with the unit.
3helpful
2answers
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2helpful
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Pretty sure this is the right model
Go to this page:
http://www.hdtvoice.com/voice/archive/index.php/t-16909.html
About halfway down are some good settings for picture, especially in theater mode on hd. As for the slant go here:
http://www.fixyourowntv.com/projection.php
Awesome site with good information. Go here for information on problems and symptoms.
http://www.fixyourowntv.com/symptoms.php
Good luck.
I'm having a problem with the picture tube on my 51 inch sony rear projection TV, 3 years old. All of a sudden the display that reads "Video 1" or "Video 2" is slanted and so is the...
It is very common to have the convergance circuit on these sets go out and cause display distortions. Are the colors separated or is just the picture slanted?
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
