That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security
Chassis Intrusion Detection
NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the
Chassis Intrusion setting.
This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the
Chassis Intrusion setting:
- Enter system setup.
- Press the down-arrow keys to move to the System Security option.
- Press <Enter> to access the System Security option's pop-up menu.
- Press the down-arrow key to move to the Chassis Intrusion setting.
- Press <Enter> to select an option setting.
- Press <Enter> again after you update the option setting.
- Exit and save system setup.
Option Settings
- On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
- On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
- Off - No intrusion monitoring occurs and no messages appear.
