I want to clean my washer out because it leaves lint all over everything.
SOURCE: Maytag Ensignia Washer Leaks
I have the same problem. Just took mine apart here is where you can see how to get the front panel off. If I figure out the problem I'll post an update.
Panel opening:
http://www.applianceaid.com/atlantis.html
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
SOURCE: how you open a maytag ensignia washer
The older models had screws at the base to remove. The newest ones have spring clips instead of screwsthis is a dryer but basically you washer fron panel comes off like this when you release the spring clips on each side with a simple putty knife.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
