Alexa Yellow ring light flashing means someone on active calling, drop-in call, incoming calling notification, When ever not any incoming call or active call and Alexa yellow ring flashing that means yellow ring light issues arise, then you need to troubleshooting.
This is most likely debris in the aerator, filter screen or check valve in the hand sprayer of the faucet. Try removing the hand sprayer and checking the filter screen at the end of the hose. The try removing the check valve to ensure it is clear of debris. It is the yellow ring with the white plastic flap in the middle. You can simply push in on the white flap and hook the yellow ring with a cork screw. Then pull it straight out. You may want to cover the drain with a dish cloth while doing this to keep small parts from being lost. If you need further help feel free to call me at Hansgrohe 1-800-334-0455. press 2 for tech and ask for David Scarborough.
are you using RCA jacks? if so make sure that you put the yellow cable in the video out spot ( out to tv) it will have a yellow ring around the opening just like the red one and the white one. ( red and white are for sound only)
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
I borrowed one of these and got most of the job done.
Here's what I ended up doing:
At a site with good drainage, a little uphill, stake down the floor of the tent Longest two poles go through the twin sleeves in the center/top. They are color coded red and yellow These two poles are anchored at the base by the center color coded ring_peg The tube ends of the fiberglass poles. Fit over these pegs.
The slightly shprter fiberglass poles go trhough the two blue sleeves. These poles get anchored on one end by a yellow ring peg and on the other by a red ring peg. They hold the vented windows up.
The arch shaped pole is threaded through a black sleeve atop the entrance to the. Tent. The arch is anchored on either side by a red ring peg on one end and a yellow peg on the other.
Stake the lines from the screen windows outwards from the tent
Spread the tarp over the top and stake the corners to shelter the screened top from rain
The optical engine has a build up of dust. This can cause yellow shapes and blotches to appear. It is no easy task on this model to dismantle and clean the engine.
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing. Open the monitor and ring coaxial wire in blue insulation.
