The dryer won't run and displays error code t5
SOURCE: how do you replace the
I am about to find out! But according to Tim Mereno, which by the way sells the part for 65. said it is not really to difficult! I will let you know.
SOURCE: maytag dryer mde9700ayw
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used.
If you find a place that sells the heating element please post!
SOURCE: Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
SOURCE: Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
SOURCE: belt diagram for maytag neptune dryer MDE9700AYW
the belt came off the pully and I need a diagram to see how it goes back on properly
I found that the code is for a thermisor and it says to check the wiring. I don't have any manuals with the unit. How can I check to make sure the thermistor is bad before I order a new one?
Do you know what resistance it should read across the contacts?
The dryer came with the house that I bought and they did not leave the manual and there isn't a wiring diagram anywhere inside it. Does anyone know how I can get a copy of the service manual with wiring diagrams?
