How do i get an item out of lint trap?
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
SOURCE: Can I remove the screen covering the lint trap?
My son used a coat hanger to pull the attachment out of the space. Then we carefully opened the top opening enough to let the top of the attachment pass out. I never did find a way to open the space to get a hand in to pull out the attachment.
SOURCE: There is a lot of lint below the trap. I want to
I have the same problem. If you find out the solution, please let me know. [email protected]
SOURCE: I can't totally clean the lint trap on my
If lint has gotten past the lint trap, you can attempt to use a brush just like the previous poster suggested. If that doesn't work you'll have to disassemble the unit. You only need to lift the top up and remove two screws on each side that connects the front to the side panels. The front should then swivel outward. Be sure to detach the door switch and wire guide from the front panel before completely removing it. You can then lift the front panel up and away. You'll need to clean the opening in the bottom of the front panel and also the entrance to the blower.
SOURCE: my wife dropped two small sticks she was using to
Yes,they must be removed to prevent damage.
We need a model number to help you.
