I am getting the same error code. The washer won't drain or spin.
AnonymousMar 05, 2009
I have MayTag MAH6500AWQ. When it gave me that error code "ND" and it did not drain. I checked the electrical waterpump. I found the connector to the waterpump burned. So, I replaced with the new waterpump. But, I still get the same error code "ND" afterward. Some suggested that the waterlines got clogged. I checked and did not see the waterlines clogged. Is there anyone know how to get it fix? Thanks, JB
AnonymousMar 19, 2014
error codeserror codes
You can't post conmments that contain an email address.
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
It says ND and won't drain completely and hasn't finished the wash cycle.
Thanks,
JB
error codes
