Hi, When I click pictures the flash does not work. The button that opens flash settings also does not respond. But when I click pictures using self timer the flash works, and the button for flash settings also works fine. What could be the problem?
Try this link below and check if this is the case.
Click here -> Nikon L10 Troubleshooting
If that does not help you, try the steps below
Click here - > Alternate Method
Regards,
Suhail
SOURCE: nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
SOURCE: self timer on nikon d300
on the top of the camera, there is a dial which says QUAL, WB and ISO. Look for button and ring just below this. It should say S, CL, CH, Lv, a clock and Mup. Press the button to release the ring and rotate it to the clock icon to activate self timer
SOURCE: Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
SOURCE: Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
SOURCE: Nikon D80 'error' and 'clock' message
La batería del reloj
El reloj de la cámara funciona con una fuente de alimentación independiente y recargable que se carga si lo necesita
cuando la batería principal está instalada o la cámara se alimenta mediante un Adaptador opcional de CA EH-
5. Dos días de recarga proporcionarán al reloj la energía suficiente para aproximadamente un mes. Si parpadea
en el panel de control, la batería del reloj está agotada y el reloj ha vuelto a la hora de inicio,
2006.01.01.00:00:00. Ajuste el reloj con la fecha y la hora correctas.
