Question about Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
  • Anonymous Mar 17, 2014
    My 8" Zeki tablet seems to be charging, what should I do?
    Top Expert:
  • 5,051 Answers
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
Posted on May 16, 2012
6ya staff
SOURCE:
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
My supersonic tablet Will not turn on how do I fix it
If the battery charge is very low, it wont start. Check the battery. Charge it for at least 4 hours and check.
Aug 03, 2015 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
Cant turn it on unless it is plugged in then when i unplug it it goes off
No battery or battery is bad. Check that the battery is even plugged in to the socket.
Oct 28, 2014 | 01 The One SKYTEX Technology Inc. SKYPAD...
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Cant get to turn on
cant get phone to turn back on
Jan 11, 2014 | Tablets & eReaders
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Jun 27, 2012 | Micro Innovations Velocity T103 Tablet PC
Le pan tablet wont charge how to reset
so my tablet wont charge but it turns on but the battery stops then turns off.so what should i do about it.
Apr 28, 2012 | Tablets & eReaders
Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook Logo
831 people viewed this question
Top Archos Tablets & eReaders Experts
Ekse
Inky Fingers
Inky Fingers
Joseph Prosser
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
