SOURCE: DVD (JVC XV-S502) Does not eject dvd. Word "lock" appears in screen
hey, this happened to me too. what you have to do is put it in standby mode, then press and hold the eject and stop button on the actual dvd player, the remote wont work doing this. this is how you can unlock and lock the dvds into the dvd player. why this is a feature jvc thought this needed im not exactly sure, but thats how you fix it.
SOURCE: JVC TH-A5R DVD DIGITAL CINEMA SYSTEM
I found the solution for my DVD player you need to hold source down for 5 seconds which will unlock the disc.
SOURCE: DVD will not eject from JVC HR-XVC27U
Disconnect the Power Cord. Open the Case and go to the DVD unit. On the right side of the unit you will see an indentation which is the mechanical portion of the DVD Unit.
Push the indentatation in, it is the eject switch. The DVD unit door opens remove the DVD stuck in the unit.
Put cover back on plug the unit in, insert a workable DVD and all should be OK.
The problem was the unit could not read a Defective DVD which I made and the unit was locked in to reading the DVD.
I hope this helps
SOURCE: JVC TH 53 Dvd surround sound system. System locked
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
SOURCE: SONY DAV-HDX900W MAKE IT REGION FREE
http://www.videohelp.com/dvdhacks?dvdplayer=DAV-HDX900W&hits=50&Search=Search
Not sure how much that helps but thats the best I can find - that should at least get you to the correct area where you should be able to fiddle around with region codes etc
