GE 24in GSD980X Dishwasher water leak in pump &motor area
Water leaks out where the motor shaft enters the pump assembly. It leaks slow when pump is running wash cycle, but leaks fast when draining. I can fix and diagnose household and car electrical. Is it a practical fix to replace what must be a shaft seal in the pump? The dishwasher is a 1995 model.
Re: GE 24in GSD980X Dishwasher water leak in pump &motor...
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Main tub seal Door gasket or seal Water-inlet valve Hoses Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
If your dishwasher leaks, check these:Main tub seal Door gasket or seal Water-inlet valve Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
1. Lower rack 2. Spray arm 3. Spray arm support 4. Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose. thanks for using FixYa
if your dishwasher leaks check out this:
Main tub seal
Lower rack
Spray arm
Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Lower rack
Spray arm
Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
If your dishwasher leaks, check these: Main tub seal
Lower rack
Spray arm
Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
hi there, dishwasher leaking might be due to either of these causes, check these:
* Lower rack *Spray arm * Spray arm support * Wash/drain impellers
Then try the seal out of its housing and replace it.
Found and installed a seal kit, about $40.
