It was plugged in last night, working fine. I left it like that, come to find in the morning it was powered off. I changed outlets and it didn't work. I took out the battery for a few seconds, put it back it and it powered on for like 5 seconds then shut off. Since then it hasn't turned on. What could the problem be. It's 2 years old. The model in the front says VPCEE-31FX
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
