Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Too much purple in sony bravia
I have adjusted the picture mode, but it is still purple and green?
    Top Expert:
  • Sony Master
  • 14,553 Answers
Try to examine the screen with the color turned off---is it a uniform color other than gray or black and white?
A photo posted somewhere with a link showing what it looks like might be helpful.
Posted on May 16, 2012
3 Suggested Answers
6ya staff
SOURCE:
Jason Morris
  • 362 Answers
SOURCE: Sony Bravia LCD KDL32M3000 picture going dark
Sounds like it may be the backlight ballast on the inverter. Hopefully you are still under warranty, Call customer support even if you are out of warranty and explain problem. In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
In Spanish: 1-800-222-7669 - Follow the (English) voice path for your product, and then select the option for Spanish support
Hours: Mon-Fri 9:00AM-10:00PM / Sat 10:30AM-7:15PM EST
If they can't help let me know and we can diagnose the problem together. Let me know if this helps and please rate this solution. LOne99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 17, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
How do you adjust vertical height on sony bravia tv
Check the aspect ratio set. If it is set to wide, there will be black bars at top and bottom of the screen. Go to its picture setting menu, and adjust the settings. If it do not help you, enter its service mode to adjust the picture height. Although this is a semi-skilled work, if you have patience and concentration, you can do this adjustment. There is no need to open the TV. If you wish to get more details about how to enter service mode, and adjust the data values there, check the site linked here. http://electronicshelponline.blogspot.com/
Dec 04, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Nov 20, 2013 | Televison & Video
Sony bravia kdl 52w3000 picture adjustment. The picture is too bug for the screen. I cant figure out how to shrink it.
I have a different Sony, but I think they all work the same. Go to menus (Press Home) Then select "Settings" and select "Screen Settings". Set Wide Mode to "full", Auto Wide to "off" , Auto Display Area to "off", Display Area to "normal". I hope this works for you
Sep 16, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Bravia 46'' picture has a slight green tint and adjusting the Hue does nothing.
hello!
that could be the t-con to main board cable's problem. first, try to tighten grounding screws.those, which connecting grounding latches of the cable.
You need to open your set. This cable is a thick shielded one with two 30 or so pins plugs. They are NOT interchangeable. In case you try to swap cable's ends. Try to move latches by hand without unplugging connectors, while TV is running. Very gently! If those moving a bit, you may see "greenge" vanishing. Tighten those screws with "phillipls" screwdriver by hand. if there is no difference, you may need to replace that cable. I'm talking about "greenish" ghosts on the picture, intermittent. If I'm wrong, it might be the main board's issue, but always start with small. Main boards are not interchangeable, factory replacement only! Cables-are.
Good luck,
Alex.
Nov 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony KP-46WT500 picture is distorted
you either need to reconverge the unit (auto focus) or you need to replace the converge chips-stk-xxx-xxx don't adjust anything.
Nov 05, 2008 | Sony KP-46WT500 46" Rear Projection...
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Bravia Color
why can't you adjust the color? What do you mean
Dec 22, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
252 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
