My iron will not get hot all lights are out
SOURCE: shark steam iron
I always purchase your Product and Irons. I like your product very much. so please provide me with address to sent this Iron back for repair. It has always made the lights in the room whenever I Iron go on and off. Also shuts off and on during ironing, then and water leaks from the iron. " Please Help"
Martin
SOURCE: SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
SOURCE: shark iron-61468-10 steam button stuck on dowm
Pull the button up. You may have to coax it up; I pried it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :) It seems like it sticks when the iron is left unused for a period of time; as if the valve sticks when dry. I'm going to leave water in it this time, although the instruction manual says not to.
SOURCE: my shark iron leaks water when I'm using steam.
Can't solve it but mine does the same. Ruins clothes.
