Service Req. 0001001 D What do I need to do ? Epson Stylus PRO 4800 PRINTER
SOURCE: color problem in Epson Stylus Pro 4800
I've had similar color management problems. I've lacked consistent color management from day one with this printer. I use standard Epson ICC profiles for paper /printer combinations. In setup I select the specific paper type (mostly Epson Premium Luster paper. SP4800 PLPP PK 288.icc profile.
I use Print with Preview, Color Handling "No Color Management". Under Print Setup I select Premium Luster Photo Paper. Under Printer Color Management I select Off (No color management).
Prints with these settings are so far off from the colors in the preview image the only thing they are good for is the shredder. I
I've gone through several hundred dollars trying to get consistent color management.
I also use an Eye One Greytag Mcbeth color management tool for both monitor, and for some papers, custom profiling. Nothing seems to improve.
I did talk with a consultant and was advised to do a good head cleaning (which was done) and also use Disk Utility to repair permissions (also done) but still no improvement.
My consultant from a reputable Pro Photo source advised me that I was not alone and that he ad numerous users who were experiencing similar color management problems. This vendor no longer carries Epson because of these continuing problems. Try the head cleaning and repairing permissions. As for me, I've been struggling twith these problems for over a year. I'm looing at trading in my Epson 4800 for an HP Z3100. This is probably overkill for my needs as it is 24 inch capacity but i like that it has an Euye One photo sensitometer built into the print heads. I'll be going to the vendor and testing this unit later this week.
SOURCE: Epson Stylus pro 4800 field repair manual
Epson is pretty cautious with their proprietary materials.
SOURCE: epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
SOURCE: I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige.
report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
