KID BROKE SCREEN
SOURCE: protron flat 32' tv with broke screen need to replace
The screen to my protron 32" broke can this be replaced
SOURCE: 32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Testimonial: "Thank you for the information. I had a feeling that I would have to replace the set."
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
