My tv had sound and no picture call westinghouse customer service they said unplugged everthing so i did then plugged tv back up now it has no sound nopicture but the indicator light below screen come on as if the tv is working. what could be the problem?
The inverter is the usual cause of that issue, some westinghouse models have the inverter combined with the power board. You can get the replacement board and free tech assistance from www.tvrepairworld.com
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: [email protected]. (866) 839-5888
SOURCE: westinghouse tv ltv46w1hd sound no picture
Need part for westinghouse LTV-46W1 no Picture
need to get Back light Inverter where to buy it.
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
