Re: Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
I've had the same problem and I did do the Pause/Cancel several times. In essense, eventually the machine will just fail to work.
Error code cell
my Kenmore he3 washer diagnostic check stops at step two with a F11 error so what is wrong?
no lights on panel, washer won't come on
