Washing Machines Logo
A
Anonymous Posted on Oct 15, 2017
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I noticed my Maytag Neptune washer leaking around the door. When I opened the door, there were pieces of the door in the washer and an actual hole in the washer door. All I put in the washer were a light load of clothes and cold water. It almost looks flaked off or melted all along the bottom of the door in addition to the hole. What happened????
epe55
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 05, 2017
epe55
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
5004
Points
10
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
1 Related Answer
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Sep 22, 2009
SOURCE: Hole Rubbed in Bottom Door - Leaks Through Front
If you can get to it you can use an epoxy made for metal or something like jb weld to patch the holes.
2answers
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
1helpful
Maytag washer MAH6500 leak - door boot issue?
there is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Machine is leaking detergent
check inner gasket for small hole
u can take front off by removing screws from around inside door frame (including hinge screws) the panel will pull out towards u then u might be able to c where its leaking better
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
2answers
The right front corner is possibly a low spot where the water is runnung to. Two possible points of the leak are the main door boot could have a tear in it or the drain pump could have a hole. It is possible to look inside of your machine while it is running. First I must warn you to take care and not touch anything inside while there is power to your machine. First open the door and you will see 2 screws on the left and 2 screws on the right sides. one pair of screwws will mount the hinges and the other set goes through a small triangular bit of metal. remove the screws and leave the door in place. The sides of the front panel between the door and edge of the machine will rotate outward slightly and the whole front panel will pull forward. at about 45 degrees the panel can be lifted off of the lower supports and placed out of the way. You will now be able to run the machine and observe exactly where the leak is coming from. Again all of the electrical connections you see are live when the machine is plugged in so do not reach inside of your machine.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
