Question about Panasonic Lumix DMC-FX01 Digital Camera
Bubbles in the photos
I have a one year old panasonic fx01 camera.the pictures display bubbles at a fixed spot.please help
  • Anonymous Jan 31, 2009
    I have a similar problem, it sounds like dust has got inside the camera and has settled on the sensor. Only solution is likely to be a service, paid or do it yourself.
    Scholar:
  • 170 Answers
Hope the problem is not with the sensor. First try cleaning the lens with a clean dry cloth. If you can't get a microfiber cloth, use a clean cotton cloth. If you can still see some smears on the lens, put two drops of lens cleaning solution on the cloth and wipe carefully.
If you still find these bubbles, take the camera immediately to an authorized service center.
Posted on Feb 04, 2009
6ya staff
SOURCE:
How do i display date on photo panasonic lumix fp3?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Just about any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jun 19, 2012 | Panasonic Lumix DMC-FX01 Digital Camera
How do i display date on photo?
Hello
  • Press MENU/SET
  • Scroll to TRAVEL DATE
  • Press MENU/SET to turn the Travel Date on
  • Repeat to turn it off
All of these instructions can be found in your online owner's manual.
Here is a link to your owners manual in case you have any quick questions!
http://service.us.panasonic.com/OPERMANPDF/DMCFX01-MULTI.PDF
Hope this helps you!
Cheers!
Feedback is appreciated!
Dec 31, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix Fz28, Error "Thumbnail is displayed"
I have this problem too, but only when I try to view pictures I have taken on a later model. Photos taken with the FZ28 view as per normal.
Jun 14, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
The lcd of my Panasonic Lumix DMC-FX01 became grey when i was taking photos. There is no problem with the photos though. The camera works without any problem. The problem is that the lcd is grey and i...
pls try to reset the camera to factory settings
performa a software reset via the menu's using the settings on the 'play' setting on the dial
if it doesnt help then
u can buy screen here and get it fixed or u can fix it is a jack mechanism inside the camera no soldering work it is not that much technical inside these devices all things are with jacks and flex cables and grips so u can do it see the link below for replacement screen from ebay and u go repair it if u go to a repair shop or panasonic they will charge u 200 $ for a 200 $ camera so dont attempt it PLS RATE ME FIXYA for help and one thing more u can check the flex cable and the connector of lcd to board may be it has some condesation and re seating might help bcoz ur LCD is not damaged as u told me no impact not broken so it might be a faulty flex cable
http://cgi.ebay.com/PANASONIC-LUMIX-DMC-FX01-FX1-LCD-DISPLAY-REPLACEMENT_W0QQitemZ220371657188QQcmdZViewItemQQimsxZ20090304?IMSfp=TL090304123003r38786
pls dont forget to rate me FIXYA
Mar 20, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01
If the dark spot is not focused, it could be on the sensor. Otherwise, check the lens for any dust particles. If you can't find any dust, take the camera to an authorized service center.
Aug 20, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
No Installation CD
Apparently there is a letter after your camera model number. I don't know if thats going to help find the driver for the camera since drivers that are available are very few for digital cameras on their website. There are a few options. You could purchase a new disk from the service center if there available or you could get a memory card reader for your camera. If you need some photo software, Adobe and Kodak has some available for free to download from their website.
Jun 26, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Black marks found on image
sir u contact ur near service center this is simple problum just clean ur camera CCD
Mar 02, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Dark circle in middle of picture
I had the same problem too! When zoomed in, those spots become very visible. I try hitting it off but it's still there.. can anyone help us???
Feb 08, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix -fx01 digicam isnt responding
After posting on here I took my FX01 to a repair centre and was informed the motherboard had died. They couldn't give a specific reason for this, saying it could be anything relating to humidity, extreme temperatures, static, even just a slight knock, etc. Cost of repair was higher than purchase of a new camera so I grudgingly went for that option. I hope you guys have better luck!
Nov 14, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
