Hi i have a packard bell easynote Mit-COU-A. Its power button d0esnt work. Can any0ne give me soluti0n?
    Top Expert:
  • 4,961 Answers
It sounds like you need to buy a new power cord for it. You could pick one up at Amazon here:
http://www.amazon.com/MIT-COU-A-MIT-DRAG-5OC-MIT-DRAG-A-MIT-DRAG-SOC-MIT-LYN01-Adapter/dp/B006VT11E8
Posted on May 17, 2012
Anonymous
SOURCE:
Anonymous
  • 46 Answers
SOURCE: packard bell easynote L4
I found a PDF document that's a service manual for an Easynote H3. It takes you to the point of removing the motherboard. I know it's a different model, but maybe it's close enough. If you want me to email it to you, send me an email at jacobson@sonic.net. It's a 1.3-MB file.
There are a lot of steps involved. I would recommend using a multicompartmented tray to hold the removed hardware. Be aware that some notebook ribbon cable sockets release the cable after you lift up on the outer shroud slightly.
If you do this job, look at the solder points first. If they look solderable, FIRST epoxy the power socket to the motherboard. When the epoxy has fully set, THEN resolder the joints. Use a low-wattage iron, not a gun.
I look at it this way: You can't make it work any less, and if you succeed, you'll be proud, and will have saved a lot of money.
Posted on Apr 11, 2008
Anonymous
  • 33 Answers
SOURCE: How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Posted on Oct 22, 2008
Anonymous
  • 5 Answers
SOURCE: Packard Bell SW51-201D (AC jack problem)
i know you can get the burntout board (where it burns out the back pin and shorts through the board) done for £45+vat at http://www.laptopsockets.co.uk/dc_socket%20replacement,_rebuild.htm
they did a lot of these for us recently
Posted on Nov 04, 2009
Anonymous
SOURCE: Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Posted on Jan 26, 2010
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: my power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Posted on Apr 23, 2010
Packard bell easynote M5284 - black screen after installing new RAM
Sounds like the memory is incompatible with the laptop. Remove the memory and install orginal memory and boot again to see if every works correctly.. If so then either a memory module is bad or motherboard wont support the new memory (size or type)
Mar 14, 2013 | Packard Bell EASYNOTE M5284 COMPATIBLE...
Packard bell easynote mit gha20 M5284 - memory upgrade
Hello Wallace.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=9B9F5310A5CA7304
Try this, i think that`s it.
mfg Gue.
P.S.: Do you know Gooooogle ?
Feb 28, 2013 | Computers & Internet
EasyNote pentium 4.I formatted my laptop of the model MIT-***-N due to virus problem and i lost the sound drivers.i have search on the net but to no avail. please help me.
http://members.driverguide.com/driver_search.php?q=Packard+Bell+Easy+One+Silver+2120&si=816f6db8f75404ec5bd996bfc9a20812&st=1299291909&device=19&gqm0=Packard+Bell+Easy+One+Silver+2120+Sound+Card
there you have different drivers.
Mar 05, 2011 | Packard Bell Easy One Silver 2120 Notebook
Easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Aug 15, 2009 | Computers & Internet
Computers & Internet Logo
326 people viewed this question
Ekse
Marvin
Marvin
