It opened when downloaded but once closed won't open up again
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
SOURCE: all of a sudden the icons are too big and don't
I believe that you may have the accessibility mode turned on. I think if you double tap with three fingers it should return to normal.
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
Here is what you need to do. First, make sure the icons aren't on another page. Swipe right on you main screen to make sure. Another possibility is that you have restrictions on which are hiding the icons. Go to Settings > General > Restrictions. If it asks for a 4 digit code, you have some restrictions on. If you know what it is, enter it. After you enter it, you have two options. You can either press the "Disable Restrictions" button, or you can go down to where it says "Allowed Content" and click Apps. At that point, make sure that "Allow all apps" is check. That should fix the problem. If not, you should reset your ipad. You can do this by holding the Home and Power button simultaneously. Let go when you see the Apple icon appear on screen. This may cause the icons to reappear. Hope this helps.
Far heros downloaded but doesn't open
When I double click the button it will show what is open. I just upgraded from 6.1 and could close what I was not using before .
How to close open apps without removing them.
