My panasonic tv is 17 system/CATV HYPER-BRAND and it is blasting fuse whenever i changes fuse it blow up and fuse that is because voltage is been doubled after that happened so plz give me suitable process to correct my tv thanks friend
[email protected]
Check for any loose solder points at its base card.
SOURCE: PANASONIC TC-20L3T
My experiance is to not put money into a TV that is over ten years
old. TVs stress out their electronic components worse than almost
any other electronic product. After 10 years, there are so many
parts that are ready to fail that your are probably wasting your money
trying to get any more life out of it.
Another option is to wholesale replace the main board by sending it to
Module Exchange at 972-298-1212, or PTS Electronics
800-844-7871 ptscorp.com.
Be careful on buying a new one though. Often times, these new
technology ones are much worse. Always Google the model number of
the set you intend to buy and add the word 'repair' or 'complaint' to
see if it is one of the many models that are customer service
nightmares being produced by even the most reputable companies today.
Hope ya fix it!
SOURCE: Samsung flat screen wide
you need to move your speakers away from the tv. turn the tv off and on about 10 times. it has a degauser built into the tv it will take the green out. also a vacume cleaner can cause this to happen. as long as it is a tube type tv.
SOURCE: Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
SOURCE: two lines appearing and moving up and down on my Pana 14"color tv
Hello, This is called 60cycle hum and it is caused by the 60Hz signal of the power supply "leaking" into the video circuitry. It is caused by a faulty filter capacitor. and can be seen by using an oscilloscope. I would suggest that you take the TV to a qualified TV technician for servicing, because this type of repair is not for the do it yourself person. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
SOURCE: I have a Panasonic 32' crt tv
some of those chassis develope small cracks or cold solder joints
should be resoldered in several areas know to have that problem
transformer pin connectors-heatsink transistors/ic's have to be checked
