SOURCE: Discrete IR code for Current model Toshiba 32" TV
these only work on the latest models HX81 etc...
pon- 0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016
0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042
0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042
0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042
0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016
0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
pof-
0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042
0016 0016 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016
SOURCE: i need the ir codes
Hello
It is not clear from your post, to which code do you need. If you are in need of Universal Remote code for Sharp TV, possible codes are given below. Proceedings also is given.If this does not help you, give me more details about your need.
Three digit universl remote codes for Sharp are:
002 013 014 111 502 509 712 812 813 913 918
Four digit universal remote codes for Sharp are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Ok
