Need a owners manual
SOURCE: Mt optimus sta-795 will not hold the station
You probably need to replace the memory capacitor. .047f 5v
off hand I don't remember the model # if you send me the catalog # on the rear of it (31-XXXX) it would help.
SOURCE: I need a service manual
I've tried unsuccessfully to find a copy you can download. The part number for the service manual is MS3102101. You can try your local RS store or call 1-800-843-7422 to see if you can order a copy.
SOURCE: I need to know what
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
