Question about Milwaukee Tool Hammering
Need diagram for kango 900 concrete hammer drill
Called kango 900
    Champion:
  • 304 Answers
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
Posted on May 28, 2012
  • john neilson
    john neilson Apr 10, 2016
    its the 1 with the red motor housing
  • Milwaukee Tool Master
  • 2,013 Answers
900 900k 950 950 k from the latest models the old english quality range of kango the bleu or red demolition or black kango rotating hammers is in all most cases the 2 important things that are no ware to get piston pins and the stroke bolt in front will leak most are worn and the seal is usually not sufficient for many years work guarantee advice is to refurbish them if they do not really turn freely when the stroke bolt is not pressed by chisel the stroke cylinder should not touch the stroke bolt it must running free and not making a marbles sound make, all of the time to spend if you have atlas copco models is disappointing because of not available parts that will be the problem the (Kango) ph11 and (Kango) pb10c are rotating and demolition models the blue old and red ones Are the original English Kango toolsandwhere much different then Atlas Copco or milwaukee in the GREASE the consistency ofthat its very different also the *****-thread was also not English anymore vs the black ones ( kango made by atlas copco) kango (Atlas Copco) made by Milwaukee these days but it has not the same lifetime and if an armature have a interchangeable crown wheel in the armature that says a lot about the quality but its over because of the new generation from Milwaukee has a lighter weight and more rpm's and less vibration and weight. but its faster defect. too small size bearing on the armature of the 900 models demolition hammer
Google Kango 900 950 Parts
Posted on Mar 24, 2016
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I need a repair manual for a Kango 900 demolition
Hi
It could need more grease around the piston or it could be the teeth on the gears are stripped
Den
Posted on Feb 24, 2010
Anonymous
  • 583 Answers
SOURCE: kango 900 demo hammer on off switch needs replacement were can
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Posted on Aug 11, 2009
Anonymous
  • 7 Answers
SOURCE: i need an schematic diagram for repair a kango
they went out of business a few years ago,i have some parts no manual i need one also
Posted on Oct 02, 2009
Re assemble kango 501 drill
Contact sales@oasistools.co.uk
Jan 09, 2014 | Hammering
I have an old Kango 900 probably produced in the early 70's. The problem now is to find drill bits that fit - any suggestions?
If it the all aliminunm with a blue handle you should have no problem. Go on to ebay.
Jan 05, 2013 | Drills
Need Parts List And Service Guide For Kango 990/950 Breaker
If these are the original Kango kangos then you are out of luck. They have been obsolete for many years now and no parts have been manufactured for a long time. The name was bought by DeWalt and they didn't do much with it. The Kango name is now ownd and used by Milwaukee, but there machines do differ alot from the originals. There were a few main models and the main mid sized breakers were the 900 (hammer only) and 950 (rotary hammer) There were a few facelift/variations of each (K, X and B I think) and they did use a couple of different sized seals/pistons/cylinders.
If it is one of the Milwaukee models you can look up diagrams here...
http://www.milwaukeetool.com/
Apr 24, 2012 | Hammering
Schematic diagram of kango 501
Hammering problems are usually caused by worn o-rings and there are a number of them. If you're not familiar with hammer's insides, you probably want to take it to a service center and have them put a service kit in. Or you can buy it too. And the service kit will come with a diagram. (Or ask them to print one out.)
If you do it yourself, remember, don't use too much grease.
Mar 09, 2012 | Hammering
I cant find kango oil for my kango electric hammer
What kango hammer do you have? I am most familiar with the UK kango 900 and 950, pre-milwaukee.
Sep 18, 2010 | Hammering
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
I need an schematic diagram for repair a kango demolition 900 bv where i get parts for it
Sep 23, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
Aug 11, 2009 | Hammering
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Hammering Logo
1,568 people viewed this question
Top Milwaukee Tool Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Milwaukee Tool Hammering Expert? Answer questions, earn points and help others
