Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Nov 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD printing error 'inner cover is open'
When i try and print on a CD print from the program 'CD-LabelPrint' the printer says that the inner cover is open and I have to close it and press OK for it to print, when I do that obviously it prints on paper which I do not want.
I got the printer settings so it is supposed to print from the CD tray, I do have a CD in the slot. I followed all the guidelines from the 'CD-LabelPrint' program for printing on a CD and it did work a few months ago when i last needed to print on CD but not anymore. Please help me I really need this to work! I want ot print on a cd and it is saying that the inner cover is not open but it is!!. Help.
  • didge00 Dec 02, 2008
    I was told it my be a sensor problem will have to get it fixed
Anonymous
Level 2:
Scholar:
  • Expert 134 Answers
  • Posted on Dec 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
134
Questions
0
Helped
119650
Points
347
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. CD printing error 'inner cover is open' - moz-screenshot.jpglose the Scanning Unit.
I hope it helps!!!
Error message Imagecache.ic not accessed. Software: CDLabel Print
The Canon Programm "CD-Label Print" has issues with Windows 7.
I solved it this way:
  1. Find the "CDLabelPrint.exe"most likely under "C:\Program Files\CD-LabelPrint"
  2. Right-Click on the File and choose Properties
  3. Select "Compatibility" and tick "Run Program ... Windows XP (SP3)"
  4. Push "OK"
  5. You should be fine now
See Picture for Details.
"File ImageCach.ic could not be accessed"
The Canon Program "CD-Label Print" has issues with Windows 7.
  1. Find the "CDLabelPrint.exe" most likely under "C:\Program Files\CD-LabelPrint"
  4. Push "OK"
Error Number : 1851 Printing cannot be executed because the Inner Cover is open. 1. Check that the CD-R tray has been removed. 2. Close the Inner Cover, and then press the OK button on the printer....
Try this Canon site for MAC driver.
http://support-au.canon.com.au/EN/search?v%3aproject=ABS-EN&binning-state=model%3d%3dPIXMA%20MP500%0Amenu%3d%3dDownload%0Aos%3d%3dMac%20OS%20X&
1helpful
2answers
Canon MP810-CD-R Tray loading-printing problem
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
3answers
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
4answers
8helpful
4answers
Printer
A support tech at Canon suggested I try this.
find the file ImageCache.ic - I found it in application data folder in My Documents, delete it.
Uninstall CD Label Print, search for any other "CD Label Print" files or folders and delete them too.
Re-boot and re-install CD Label Print.
This worked for me. Hope it works for you too.
Cheers
OM
2answers
Dvd and cd printing
This is an easy fix by creating your own template....choose program "cd-labelprint" >> file >> select paper >> new >> (select a name to save as) (select diameter sizes etc) >> OK.
2answers
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Printer program
i think driver u have installed is not support cd label print. u go to your vender who provide u printer. or u have better option to upgrade your driver which support cd label print. good luck purushotam
old marine
old marine
ZJ Limited
ZJ Limited
