I seem to have pressed the play and eject buttons on my system and the display showed Lock then Demo Play. There is no disc in the tray.
The manual says consult a service centre when the display shows this. I got my system in May from the US and I do not have a Sony Service centre in my country.
Is there a way to rectify this problem?
Right the problem for me was that it was in demo mode. play + stop key press resolved my problem after same key press to remove player from demo mode and switched off then play stop to remove from locked mode.
I have waited 2yrs for this solution!! Thanks Fixya!
While the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out. In some models you need to turn off the power and turn it on while pressing the EJECT Butoom. SONY SPECIALIST
The locked display shows can be removed There is some way for that. a reset cannot make it. Visit these sites. Search them with your blu-ray model number, at its search box at the right column; please visit them on a desktop computer; it only have the search column; and see how to remove the tray lock. The website have many useful service manual of above "5600" various sets. https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/
<span style="font-weight: bold;">Blaupunkt:</span><br /><br />
<ol>
<li>Press the (PWR) to turn the unit off.</li>
<li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li>
<li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br />
<ol>
<li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br />
<ol>
<li>Unplug the unit and wait ten seconds.</li>
<li>Plug it back it and press repeatedly on the eject button.</li>
<li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br />
<ol>
<li>Press and hold the "D" button to enter the settings menu.</li>
<li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li>
<li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br />
<ol>
<li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li>
<li>When the software version window come up, hit ENTER.</li>
<li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li>
<li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br />
<ol>
<li>Hold down the SEL button for 2-3 seconds.</li>
<li>Use the << or >> buttons to find DEMO.</li>
<li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li>
<li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br />
<ol>
<li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li>
<li>Use knob to select demo.</li>
<li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br />
<ol>
<li>Switch to Standby.</li>
<li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li>
<li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br />
<ol>
<li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span>
<ol>
<li>Turn the vehicle's key to the Accessory or ACC position.</li>
<li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li>
<li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li>
<li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br />
<ol>
<li>Turn the radio off.</li>
<li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li>
<li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br />
<ol>
<li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br />
<ol>
<li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li>
<li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br />
<ol>
<li>Press display twice to turn off Demo mode.</li></ol>or<br />
<ol>
<li>Press and hold the select button.</li>
<li>Press the select button repeatedly until the desired item appears.</li>
<li>Rotate the control dial to select the setting DEMO.</li>
<li>Rotate the control dial to select the setting DEMO-OFF.</li>
<li>Press and hold the select button.</li></ol><br />or<br />
<ol>
<li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li>
<li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo
mode. now press the power button while
pressing the stop and eject button,clear all will display
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened. There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system. Unlocking Procedure 1To turn off the Dealer
Lock function, follow these
steps:
Turn on your Home
Theater System.
Press the Stop button
on the front panel and
the Power button on the
remote control simultaneously
for four seconds.
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2To turn off the Dealer
steps
Turn on your Home
Theater System.
Press and hold the
Function button on the
front panel for 3 seconds.
The display shows the
word Unlock.
Note: Repeating
Unlocking Procedure 3To turn off the Dealer
steps
Turn on your Home
Theater System.
Press and hold the
Open/Close button on the
DVD player on the front
panel for more than 4
seconds.
Note: Repeating
the two steps above turns Dealer Lock on again. Unlocking Procedure 4To turn off the Dealer
steps
Using the HTS remote press the Menu button + 712, and the HTS will display
CAN OPEN.
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’. 2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below) 3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary information then stop at a main menu screen. 4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during playback. 5.Use the direction button on the remote control to select the desired option. Press ENTER to select the option or press the ► button. Playback will now commence. 6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the disc. Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the function is not supported at the current time.
Just try to initialize THE plager again.
Without cd in the player switch on the power while pressing the Play, Open and Next Track button.
On the display it says " initialized" Ready.
Frits van Heekesen
Nijmegen The Netherlands
while the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out. In some models you need to turn off the power and turn it on while pressing the EJECT Butoom.
SONY SPECIALIST
There is no disc in the tray! After pressing play and stop the display shows DEMO OFF and then NO DISC. When press any other button shows LOCKED
