Here are my interests below 1- very high image quality 2- will be used family photos and children 3-I'm fast learning new stuff 4- never had slr in the past Please advice me
They both take superb pictures. The D3200 is slightly easier to learn how to use, while the D5100 is easier to use once you learn it. That is, the D3200's menus will guide you through all its settings, while with the D5100 you can change those settings with less work once you learn the proper buttons to push. The D3200 has a higher resolution, but even the D5100 will take photos that can be enlarged to 8x10 and larger.
I suggest you go to a good camera store and try them both out. See which one better fits your hands. You don't want to buy a camera based on specs, or other people's opinions. You want a camera that best works for YOU. Having said that, the D3200 is probably a better first SLR. However, try them both out and choose the one that's better for YOU.
SOURCE: Nikon Coolpix L11 - LCD screen shows double image
It could be a loose LCD connection carefully take off the back and lift the LCD very carfully you will see the ribbon cable lift the tab take out the LCD and reinsert it and push the tab back down. If this does not fix it you might have a damaged main board its one or the other.
SOURCE: Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
SOURCE: can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
SOURCE: SLR Camera : Nikon D90, dropped from 5ft and landed on Road
There is an almost certainty that your mirror and shutter is going to experience problems in the future. Any fall of that nature is SURE to jar the shutter and the mirror very badly. The shutter is probably damaged already. Go out in the bright sun and shoot on shutter priority at the highest shutter speed (I think the 90 is 4000 /s?) and see if the shutter makes a stuttering noise...Also go into your menu and set the mirror to "Lock up" (for cleaning purposes), if both of these things work ok, you should be ok for a while. But do not depend on the camera for anything really important such as weddings unless you have a backup camera...
SOURCE: Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
I'm Still not happy with the First Solution came from K_akima
What else would you like to know? Both are quality cameras, fully meeting your stated desires. You can see the specs for them on Nikon's web site. I can't comment on their prices since you didn't say where you are, and dealers periodically offer special prices. Nor can I speak for your personal preferences.
