SOURCE: freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all.
Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful.
If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction.
If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK.
If you hear nothing, then it might have failed.
SOURCE: whirpool side by side refrigerator ,fridges is not cooling at all
HI.YOU MIGHT WANT TO CHECK IF THE FAN IS WORKING WELL OR IF THE UNIT IS NOT OVER FREEZING WHICH CAN E A CAUSE OF THE FRIDGE NOT COOLING PROPERLY.FEEL FREE TO REQUEST MORE ADVICE IF NEEDED
SOURCE: The divder between my frig and freezer is also hot
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
SOURCE: where does freon go?
If freezer is working the freon is fine. There is a air flow problem. Air has to circulate between the frig side and the freezer side to cool it.
Eric
SOURCE: Not cooling good
There is a fan down by the compressor that aids in cooling compressor and getting rid of the water that comes out of the freezer during defrost cycle. I am sure that you took the paper cover off the back of the unit on the lower back side so your unit might not have a fan. Now lets look at the fan inside the freezer is it running can you hear it when you open the door? Does the compressor make a clicking sound as it is hot to touch and trying to come on? get back with me ok ken
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
