Question about Poulan Pro 25CC 2Cycle Gas Blower
Pull cord frozen
Can't pul cord after blower stalled while using.
    Brigadier General:
  • 6,468 Answers
If it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
Posted on May 20, 2012
  • Sean McNamara Nov 27, 2012
    If the fuel mixture was done impropperly, how do I best remedy the problem? I have drained the wrong mixture, but want to know if I should manually lubricate or do anything else to the engine before refueling with the propper mixture and running the blower.
6ya staff
SOURCE:
Pull cord in my storm force snow blower will not retract how do I fix it?
Either it is frozen in which you can use a hair dryer or heat gun to warm the rewind or the spring may be broken. Check out this youtube video
How to Repair Small Engine Recoil Starter
Jan 20, 2016 | Stormforce Garden
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
My 4514 Honda has a snow blower for the winter . It keeps stalling and the fuel pump never shuts off so I guess isn't pressurizing . I pulled the fuel line at the carb & it is pumping gas ....
sounds as if there is sticky gum in the carb that is keeping the float from seating unless it is hot enough to unstick. Take the carb bowl off and examine it for gum (real old gasoline will do that.
Feb 02, 2015 | Honda Cars & Trucks
Why is my security light blinking and wont start?
The most common problem is your lock cylinder.
The lockcylinder is equipped with spring loaded contact to touch the chip on the key. After years of use the spring collapse.
Disconnect the battery,remove airbag,remove steering wheel, remove column cover,disconnect orange wire under the dash,turn ignition switch to running position and push the locking pin with small pick . Pull the old cylinder out (tight fishing cord to the end of the orange wire before you pul and use the cord to pul the new one back)
Buy AC Delco plain cylinder and rekey to your old key.you're saving money from reprogramming the new key
Install in revers order
Good luck
Aug 15, 2014 | 1999 Chevrolet Silverado 1500
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
Blower stopped working Empire Stove Model # RH655 Ser T40891422
Beth, first check the blower's cord to be sure that it's still plugged into the wall outlet. Also, check your home's circuit breaker panel for a tripped circuit breaker, that is feeding that outlet.
On the mechanical side there's 3 things that need to be done:
1. Check the Fan Control by shorting across the terminals.
2. Check for blower wheel binding, by removing the wheel and operating the motor.
3. Check for frozen bearing due to a lack of oil.
To further help you with a parts breakdown, I have included a link to the Owner's Manual for your Model. You can download & print it if you like.
http://www.empirezoneheat.com/assets//EHS/manuals/128
If you continue to have a problem with it , contact Empire Comfort Systems Technical Service @ 800-851-3153.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
When i pull the starter cord it pulls back really hard
pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
Apr 15, 2010 | Craftsman 8.50 Torque Rating Dual...
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
Black and decker blower cord smokes when pluged in and trigger is pulled
Suggest you not use this equipment. Either you or someone else could be shocked. If the blower cord is getting hot, so is the drop cord. Something may melt and cause a fire. My guess is a short in the blower unit itself, which should only be addressed by a professional or replaced if too old to fix.
Oct 24, 2009 | Garden
Poulan Pro 25CC 2Cycle Gas Blower Logo
705 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
