Question about GE WHRE5260E Top Load Washer
I have a GE whre5260E1ww washer that runs cycles erratic. Sometimes stops mid cycle.
I see others have had the same symptom. Here is my story / question. I have a GE whre5260E1ww washer that runs cycles erratic. Sometimes stops mid cycle. Sometimes will hang with a single LED on. Also if the washer is bumped it will appear to reset (almost all LEDs flash), can duplicate by taping (enough force to scoot a bag of sugar about 1/4") the control panel near the cycle switch. I removed the control board and examined it for problems or defects. I found a couple component leads bent too close to the next trace, and a couple solder balls trapped in the comformal coating that appeared possibly bridging to a nearby contact or trace. I also found the cycle rotary switch (SW1) while looking great on the solder side, looked very corroded on the shaft side. The switch steel mounting frame is rusted, and the contact legs have green (copper) corrosion deposits on the tinned surface. I am unable to find the part number of the ALPS switch used, nor have I found a schematic or parts list for the control board. Any help ? Am I looking in the wrong place for the original problem ? Thank you.
  • junk24
    junk24 May 21, 2012
    Update:
    I unsoldered & swapped the cycle switch for the water temp switch. All three including load size are same part number switch, but the temp switch had much less corrosion on it. That seems to have cleared up the original problem, and bumping the washer or switch has no effect anymore. However the level switch is also sensitive and will stopped filling, until tapped gently. Probably could not see that from all the resets. I think GE did not make this machine as well protected from the wet corrosive (bleach, etc) environment as it should have.
    If someone finds the common part number for the rotary switches I hope they will post it here as an answer. Thanks for looking. Hope it helped.
3 Suggested Answers
6ya staff
SOURCE:
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Posted on Dec 08, 2008
tbirdfan1
Michael Thomas
  • 3051 Answers
SOURCE: GE whre5260e1ww zh133346g top load washer is
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Posted on Nov 13, 2009
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
My maytag epicz will run water and then just stop it lock and later get code f33
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Jan 23, 2008 | GE WHRE5260E Top Load Washer
GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Nov 17, 2007 | GE WHRE5260E Top Load Washer
Cycle not completing and spinning erratically
We had the same problem. We unblocked the filter (found a hair grip, a belt buckle and a sock) and with luck it will be fine now. To unblock the filter pull down the little white round flap on the front of the machine and unscrew the filter. Beware though water may pour out when you unscrew the filter.
Oct 03, 2007 | Whirlpool AWM5125/1 Front Load Washer
GE WHRE5260E Top Load Washer Logo
170 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
